Dear Community Members, We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience. SE Community Team!
Posted: 2020-07-03 05:15 AM . Last Modified: 2024-04-08 11:24 PM
-on behalf of john.campbell@eumetsat.int -
Running DCO 7.5, we have been using the Webmin functionality of mounting SMBFS shared to exchange CSV files with external applications. Currently testing 8.0, SMBFS has disappeared and we are not able to find a working equivalent.
Any suggestion?
Thanks 😀
(CID:107448569)
Use Common Internet Filesystem (CIFS) which should work like SMBFS.
https://en.wikipedia.org/wiki/Server_Message_Block
(CID:107448601)
(CID:107448601)
Thanks for the tip! Now I am just having permission problems
(CID:108234872)
Posted: 2020-07-03 05:16 AM . Last Modified: 2024-04-08 11:24 PM
Fixed by removing the domain name from the username field and use the workgroup field instead.
(CID:108235219)
Posted: 2020-07-03 05:16 AM . Last Modified: 2023-10-31 10:47 PM
