Put 2 devices on the same unit
  • EcoStruxure IT forum
  • Put 2 devices on the same unit
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 10:43 PM . Last Modified: ‎2024-04-04 02:47 AM
806
hello,
How do I put two devices on the same unit?
When I move device into the closet it grabs me the whole unit.
version 8.2.2
(CID:134026328)
  • Data Center Operation
Posted: ‎2020-07-04 10:44 PM . Last Modified: ‎2024-04-04 02:47 AM
805
Hi Roni,
Try using "Shelf":
And make sure the equipment is "Shelf" mountable:
then you can place the devices/servers/equipment on the shelf.
Kind regards
(CID:134026425)
Replies 5
Hello Roni. Are you referring to placing a couple of devices at the same Rack U position in a rack?
Are they small devices which could fit side by side? If yes, then may be able to use the "shelf" genome in DCO to place a shelf in the rack at the U position you'd like, then make sure the genomes (asset library definition) for the devices you want to place side by side are set to allow the device to be placed on a shelf.
For example this mac mini genome is set to be shelf mountable in its mounting properties (see screenshot).
Regards
GregS
(CID:134026399)
806
Hi Roni,
Try using "Shelf":
Kind regards
(CID:134026425)
Thanks alot
(CID:134028006)
You are welcome, Roni
Kind regards
(CID:134028009)
Posted: ‎2020-07-04 10:44 PM . Last Modified: ‎2023-10-22 03:40 AM
This is a heading
