Power Monitoring For Floor Mounted Equipment
  • Power Monitoring For Floor Mounted Equipment
127
Posted: ‎2020-07-03 08:52 AM . Last Modified: ‎2024-04-08 03:43 AM
574
Is it possible to see the power readings (from a monitored breaker) from a floor mounted piece of equipment that is connected directly to a breaker (tap-off)?
(CID:110007561)
  • Data Center Operation
Hi James,
I don't think that would work for floor mounted piece of equipment (I have tested few moment ago, but didn't work), I'm almost certain that the branch circuit monitoring feature is designed for PDU/rpdu.
I was wondering perhaps we could use (if needed as a work-around) a combination of a "rack+rpdu" and call it "floor mounted device".
Kind regards
(CID:110007604)
Posted: ‎2020-07-03 08:52 AM . Last Modified: ‎2023-10-22 03:36 AM
