Posted: 2020-07-03 08:53 AM . Last Modified: 2024-04-08 03:43 AM
HI,
Recently our customers have put forward some demand,
Want to customize the DCO, DCE interface theme style.
1, how web Dco default language is Chinese
2, custom Login web title
3, custom web DCO themes and backgrounds.
4, change some text translation
5, in the WEB DCO, add gadget, such as PUE, power consumption history, DCE temperature, humidity and so on.
Although it is now mostly on the Web, but do not rule out the possibility of the client also need
(CID:110007574)
Hi guanyc
I can only answer few of your questions:
1) DCO web client uses web browser "Preferred language" on the first login. If this is not set, it would default to English.
If you are creating user via REAT API you could specify user's language when the user account is created.
3) Read this page: Customizing web branding
4) Normally altering of the user interface messages is not supported. Do you think that Chinese translation is not good enough?
You can read more about using desktop client in multiple languages here: Working with multiple languages
(CID:110007587)
Thanks for reply 1, there is no way to let the "language Preferred" is Chinese do? 2, some translation, customers want to change
(CID:110007612)
Hello guanyc , Is there an error in translation in the user interface? It would be helpful to know what the customer is requesting specifically. Thank you.
(CID:110007614)
Not all, customers can not understand the word, want to change
(CID:110007621)
Which word?
(CID:110007641)
Posted: 2020-07-03 08:53 AM . Last Modified: 2023-10-22 02:28 AM
