Posted: 2020-07-02 09:46 PM . Last Modified: 2024-04-09 01:40 AM
Hi All,
I have two question about Power Meter which is discovered Modbus TCP;
Thanks for advice emrekoca
Kerem
(CID:105459281)
Posted: 2020-07-02 09:47 PM . Last Modified: 2024-04-09 01:40 AM
Hi Kerem,
Regarding question number 1:
I believe device state status as "–" is normal behaviour. I see the same on my test environment. Normally would it also be Data Center Expert which is used for the alarm monitoring of the device.
Jesper
(CID:105459645)
Hi kerem.yilmaz - thank you for posting. Let's see who can be of assistance here. Meanwhile, @community - any ideas?
(CID:105459560)
Thanks Stine.. One other issue is, power meter alarms action which is "Send E-mail" receive just "Power Meter-Hosname"format. My customer wants to specific name and subject such as Rack Pdu like "Row C - PDU A". Regards
(CID:105459577)
Hi Kerem yilmaz,
You can set the name or location of device through custom property editor see the below procedure and screenshots.
1) go to windows tab and select the custom property editor
2) click on key symbol in the right corner and put the name (Location or name of device)
3) click on power meter device and write the name of device.
4) if you want to see the name on map view then go to edit map option , map setting and select the name which you created in custom property.
BR,
Rana Ajmal
(CID:105459620)
Dear Rana, Thanks for your answer. So, i added some custom property and i tested alarms but mails received same subject. Have you any solution for changing alarm mail subjects or how can i change mail subject or add location from mail subject. Regards Kerem Yılmaz
(CID:105459651)
Hi Kerem, Try to use macro in '' send short message E-mail'' may it will help you. Regards, Rana Ajmal
(CID:105459658)
Hi Rana, I have already know that way, but alarm mail which is sent from "Send Short Message E-mail" has not a good template and no data chart like "Send E-mail" action that customer wants. Of course, if we have no other choice, we must set "Send Short Message E-mail" actions. Thanks Kerem
(CID:105459664)
Hi Kerem,
Jesper
(CID:105459645)
Thanks Jesper.
(CID:105459646)
We had achieved results especially with Modbus and BACNET devices using the customized DDF for these devices and setting Static property in ddf like this:
This will display it in Location field of SXW DCE like you want without creating customized property.
(CID:105459696)
Posted: 2020-07-02 09:47 PM . Last Modified: 2023-10-31 11:30 PM
