We Value Your Feedback!
Could you please spare a few minutes to share your thoughts on
Cloud Connected vs On-Premise Services. Your feedback can
help us shape the future of services.
Learn more about the survey
or
Click here to Launch the survey
Schneider Electric Services Innovation Team!
Posted: 2020-07-02 09:45 PM . Last Modified: 2024-04-09 01:41 AM
I've installed Portal v1.3.2 over a RHEL6 server and when I access to the Portal with serverIP:8080, I cannot see the public pages as I can see with older version, it appears a signin screen to login.
Attached you can find a screenshot.
How can I see the public pages without login?
Enric
(CID:105459242)
Posted: 2020-07-02 09:46 PM . Last Modified: 2024-04-09 01:40 AM
Hi Enric
I have bean looking into log files that you have provided, and I am not able to see any issues regarding startup, missing war files or anything regarding your issues.
I would suggest that you reinstall StruxureWare Portal by uninstalling it and install it again.
if you have done some customization of your StruxureWare Portal I would suggest that you take backup of database and data folder.
you can find guide on how to backup and restore StruxureWare Portal here: http://dcimsupport.apc.com/display/public/Portal/StruxureWare+Portal+backup+and+restore
otherwise you can just uninstall it and install it again.
Please let us know if you have any issues.
/Elvedin
(CID:105460368)
Hi Enric Climent, thanks for posting. Let's see who can be of assistance here. @community any ideas?
(CID:105459556)
Posted: 2020-07-02 09:45 PM . Last Modified: 2024-04-09 01:40 AM
Hi Enric Climent, it seams that your theme is not getting deployed, we are investigating issue, can you upload log files, you can see how you can find log files here: http://dcimsupport.apc.com/questions/105458527/how-to-collect-struxureware-portal-server-logs regards
(CID:105459663)
Hi Elvedin, I've uploaded the logs. Best regards, Enric
(CID:105460150)
Hi Enric
/Elvedin
(CID:105460368)
Hi Elvedin, I've reinstalled the Portal and the problem has not been solded, Regards, Enric
(CID:105461325)
Hi Enric I will investigate you issue again, in meanwhile can you send us install.log file witch is located under /opt/StruxureWarePortal/ library you can upload it to same directory as log files you previously have uploaded. Regards /Elvedin
(CID:105461975)
Hi Enric I have bean doing more investigation on this issue, and I have successfully installed StruxureWare Portal on RHEL6 6.0 with out any issues. I was wondering how it's going on your side did you resolve issue, and if not are you able to get install log files that I have mentioned above, Kind regards /Elvedin
(CID:105467239)
Posted: 2020-07-02 09:46 PM . Last Modified: 2023-10-31 11:29 PM
