Portal to Ldap User Connection
  • EcoStruxure IT forum
  • Portal to Ldap User Connection
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 01:28 AM . Last Modified: ‎2024-04-09 12:35 AM
916
Hi All,
I have created a connection Portal to Ldap succesfully, but when i try to import user i have an message that i do not know what it is. So as you can see attached images, can you say any advice or my wrong value on filling textbox..
Regards
Kerem
(CID:105469818)
  • Data Center Operation
  • Portal
Hi Kerem,
As you've mentioned, it seems you have successfully setup your ldap authentication in Portal. I think the test ldap users notification, as it says, would like to notify you that some ldap users might not be imported, because of the required attributes. The required attributes are: Screen Name, Password, Email Address, First Name and Last Name - you might want to check these required attributes (for the possible missing users) in your LDAP server.
You might want to visit the following page, that describes a basic LDAP integration in Lifray/Portal:
https://www.liferay.com/community/wiki/-/wiki/Main/LDAP+with+AD+in+Liferay+6.0.5?_36_pageResourcePri...
Hope this helps,
Kind regards
(CID:105470029)
Hi Kerem,
Hope this helps,
Kind regards
(CID:105470029)
Posted: ‎2020-07-03 01:28 AM . Last Modified: ‎2023-10-31 11:29 PM
