Portal and DCE using HTTPS
  • EcoStruxure IT forum
  • Portal and DCE using HTTPS
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 03:42 AM . Last Modified: ‎2024-04-08 11:53 PM
835
I recently performed a configuration for a customer who is using HTTPS only on DCE. I was having difficulty getting portal to connect to DCE using HTTPS. Is there a known issue or resolution for this? I've tried pointing to DCE with the following strings:
  • https://
  • :443
  • https://:443
Thanks in advance for the assistance.
(CID:106207070)
  • Portal
835
Hi Jeff,
Currently Portal does not support HTTPS connection (to neither DCE nor DCO).
The next version of Portal will support the https connection - it is expected to be released at the same time as DCO release.
Kind regards
(CID:106207158)
Replies 4
836
Hi Jeff,
Kind regards
(CID:106207158)
Thanks for your timely answer, Jef. Has this indeed been released with DCO 8.x?
(CID:106210610)
Posted: ‎2020-07-03 03:43 AM . Last Modified: ‎2024-04-08 11:53 PM
Hi Jeff, You are most welcome - yes, the Portal (v. 1.3.3) that is released with DCO 8.0 supports the https connection. Kind regards
(CID:107448163)
Posted: ‎2020-07-03 03:43 AM . Last Modified: ‎2023-10-31 11:29 PM
