Please set correct voltages on rack PDU to enable phase selection.
  • EcoStruxure IT forum
  • Please set correct voltages on rack PDU to enable phase selection.
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 10:16 PM . Last Modified: ‎2024-04-03 12:31 AM
830
We have the following power path on DCO for our customer’s installation:
Generic 3P Power Panel => 16A 1P Circuit Breakers (2x, on phases L1 and L2 respectively) => Left & Right 16A PDUs => IT equipment
We are facing the following issue when trying to select power dependency on any of the rack IT equipment: “Please set correct voltages on rack PDU to enable phase selection.”  (see screenshot below).
I am also attaching screenshots of the settings of the various equipment of the power path.
Could someone explain how I can solve the above issue?
(CID:148771616)
  • Data Center Operation
  • bug
HI!
Did you check Power Panel output voltage? It's 208V by default if I'm not mistaken.
You should set it to 400V.
(CID:148771881)
Posted: ‎2020-07-05 10:16 PM . Last Modified: ‎2023-10-22 03:33 AM
This is a heading
