Posted: 2020-07-03 03:17 AM . Last Modified: 2024-04-09 12:00 AM
Hello.
How ca I create/modifiy the dimensions of a perfored Ceiling Tile
Best Regards
rma
(CID:106205585)
Hi Rocchino,
Unfortunately modifying the dimension of a Perforated Ceiling/Floor Tile is not supported, the supported option is to change the tiles Perforated ration and/or its Measured airflow.
Kind regards
(CID:106205590)
Hi Rocchino,
Kind regards
(CID:106205590)
Hi jef, tks for your answer but how can I do if I need half tile for my roof because my room is not square:( Best regards Rocchino
(CID:106205671)
Hi Rocchino, I understand the issue & sorry for the disappointment, I believe there is a registered feature request for "half tile perforated tiles", I will go ahead and you to this feature request and will email you the case no, thanks. Kind regards
(CID:106205672)
Hi Jeff, tks a lot best regards Rocchino
(CID:106206040)
Hi Rocchino, You are welcome, Kind regards
(CID:106206053)
Posted: 2020-07-03 03:17 AM . Last Modified: 2023-10-31 11:28 PM
