Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
Packaging of the DCO client
  • EcoStruxure IT forum
  • Packaging of the DCO client
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 06:06 PM . Last Modified: ‎2024-04-03 03:07 AM
713
Hi Team,
Asking on behalf of customer.
They are trying to preapare for the DCO client packaging.
Below are the questions I received from them:
"Is there anyway add custom variable like “AppvFolder” which point to “c:\programdata\Microsoft\Appv” folder?
Need modify config file at osgi"
Your help is much appreciated.
(CID:140714878)
  • Data Center Operation
Posted: ‎2020-07-05 06:07 PM . Last Modified: ‎2024-04-03 03:07 AM
713
Hi Lukasz,
I've got this (from a developer), based on documentation on the framework we use (Eclipse) - the only 2 variables that make sense here and can be handled by the application are these:
@user.home
Directs Eclipse to compute a location value relative to the user's home directory. @user.home can be followed by additional path segments. In all cases, the string "@user.home" is simply replaced with the value of the Java "user.home" System property. For example, setting
osgi.instance.area=@user.home/myWorkspace
results in a value of
file:/users/bob/myWorkspace
@user.dir
Directs Eclipse to compute a location value relative to the current working directory. @user.dir can be followed by additional path segments. In all cases, the string "@user.dir" is simply replaced with the value of the Java "user.dir" System property. For example, setting
osgi.instance.area=@user.dir/myWorkspace
file:/usr/share/eclipse/myWorkspace
Kind regards
(CID:141264505)
Thank you Jef,
Only just saw the reposne.
I will communicate to my customer and seek his further feedback.
(CID:141266365)
Posted: ‎2020-07-05 06:07 PM . Last Modified: ‎2023-10-22 03:32 AM
