PME Integration
  • EcoStruxure IT forum
  • PME Integration
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 12:10 AM . Last Modified: ‎2024-04-09 12:59 AM
2135
PME Integration
Hi All,
Do you have any experience and best practice example for DCO&DCE integration with PME?
Kerem
(CID:105466358)
  • Building Operations
  • Data Center Operation
  • power monitoring expert
2135
Hi Karem, DCIM Support has a dedicated section on Configuring StruxureWare Power Monitoring Expert integration, hope this helps.
(CID:105466400)
Replies 6
2136
(CID:105466400)
Hi Ajay, I know that pdf before. I just hope what is the best practices of that. I mean that integration is used just monitoring or can i create a report. Can i associate PME nodes with DCO devices? with So, i need any experience for that integration. Thanks kerem
(CID:105466401)
Hi Karem, once PME devices show up in 'unassociated devices' pane, you can either auto associate (based on matching fields http://dcimsupport.apc.com/questions/105464964/etl-import-auto-association-fields ) or a manual association with DCO devices.
(CID:105466424)
Posted: ‎2020-07-03 12:11 AM . Last Modified: ‎2024-04-09 12:59 AM
Hi Ajay, Thank you again. So do you know can DCE integrate with PME? Regards Kerem
(CID:105466425)
Hi Karen, we have some experience drawing alarm and performance data from PME into SBO if that helps.  Feel free to email
Cheers
Ed
(CID:105466487)
Posted: ‎2020-07-03 12:11 AM . Last Modified: ‎2023-10-31 11:29 PM
This is a heading
