Posted: 2023-03-01 06:15 AM
Hi all,
i have around 400 pdus in my DCE tool. I want to change all their usernames and their passwords with the same username and password. is there any case that i can do that to all pdus simultaneously and not one by one?
Thank you
Posted: 2023-03-01 09:40 AM
Use device configuration and create a template edit the user name and password in security I think then select all the rPDU's and configure using the template you created and it will configure them all at the same time 👍🏻
Posted: 2023-03-01 09:42 AM
Sorry forgot to say select all the devices then R click and select SNMP devive configuration then follow the above
