Posted: 2020-07-05 01:02 PM . Last Modified: 2024-04-04 12:40 AM
I checked DFF file for Ecostrxure but there is no one for Uniflair PCOweb.
Is it possible to add a PCOweb in Ecostruxure because when I searched the product with SNMP I obtain this error :
Should I try to discover with advanced mode?
Thanks in advance for your help.
Regards.
Samuel
(CID:134685542)
Dear Samuel,
Uniflair PCO web SNMP is indeed supported on EcoStruxure IT gateway 1.4.0.
When you are discovering the device, select "Advanced" and Uniflair device as shown below.
I hope this helps.
Bala
(CID:134685552)
Dear Samuel,
I hope this helps.
Bala
(CID:134685552)
Posted: 2020-07-05 01:03 PM . Last Modified: 2024-04-04 12:40 AM
Hi Bala,
I will checked.
Thanks a lot for your help.
Regards
Sam
(CID:134685577)
Hi Samuel,
You can try with this DDF
(CID:134685888)
Dear Jesus Banegas,
The DDF-file you specified is the file for the DCE software.
This topic deals with the new free software EcoStruxure IT Gateway, which uses a signed DDF catalog. In this software, a user cannot add or delete DDF-files. At the moment, the signed DDF catalog is modified and updated with each new release of this software.
With respect.
(CID:134685968)
Posted: 2020-07-05 01:03 PM . Last Modified: 2023-10-22 03:29 AM
