OutDoor Cameras that can Tie in to DCE?
  • EcoStruxure IT forum
  • OutDoor Cameras that can Tie in to DCE?
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 03:11 AM . Last Modified: ‎2024-04-09 12:02 AM
944
What are some reliable options that I can use for surveillance of my equipment outside of the server room?
We have Netbotz and cameras but obviously we do not want to have these outside.
We have Data center expert and we want to easily tie in the system to DCE is it possible?
(CID:106205390)
  • NetBotz
944
Hi
You have 2 choices here:
  1. Install compatible Peco IP Cameras outside.
  2. Use the CCTV adapt or pod to integrate existing analogue cameras that you may have.
Regards
Aaron
(CID:106205397)
Replies 5
945
Hi
Regards
Aaron
(CID:106205397)
Thanks Aaron. Any suggestions on the IP Camera.
(CID:106205404)
Here is a link to the compatable Pelco Cameras: Pelco cameras tested with NetBotz - Regards Aaron
(CID:106205416)
Thank you Aaron.
(CID:106205531)
Posted: ‎2020-07-03 03:11 AM . Last Modified: ‎2023-10-31 11:28 PM
