Posted: 2020-07-04 02:41 PM . Last Modified: 2024-04-05 02:33 AM
I am having issues downloading the Spoon client library from the ETL Integration Management page in DCO Webmin. I have tried 3 different browsers and windows 7 and windows 10. It downloads the zip file, but there is nothing in it even though it says its 3,863 kb then when I try to extract it I get this error "The compressed (zip) folder is invalid".
(CID:128762632)
Hi Christopher,
I've tried several times without any problem. In Windows 7, I downloaded the zip file "spoon_package.zip" 3.863 kb (from webmin interface)
and then double clicked (or right click > 7-zip > Open archive), it contains a folder without name, which needs to be opened as well. Then you should have the following folders "plugins" and "lib" (both folders contain files!):
Kind regards
(CID:129403239)
Posted: 2020-07-04 02:41 PM . Last Modified: 2023-10-22 03:27 AM
