Network route to long
  • Network route to long
129
72
Posted: ‎2020-07-03 03:38 AM . Last Modified: ‎2024-04-08 11:55 PM
1427
Hello community and support,
I have a question about the Network Route Path in DCO.
When i add a long route in the network management view that contains more than 256 characters i must gamble the next step becouse it's not possible to add more characters in the path.
I have already adapt the names of the rooms, row's racks and servernames but it still doesn' t fit!
Is it possible to simplify the way to make or edit network routes?
Or is there in the next upgrade a better solution for editing the network routes?
Many thanks for your help.
(CID:106206859)
  • Data Center Operation
1427
Hi Stefan,
I was wondering if using the "Connection tool" could be the feature you were looking for - as illustrated by selecting for example all my 7 racks (by holding the "Ctrl" and clicking the left mouse button on racks), I can easily make the network route from rack 1 to rack 7.
I was also trying to see if I could reproduce the character limitation in "Edit route" field, but as illustrated in the following capture I have over 256 characters (at least 292 in this test):
My tests have been on a DCO 7.5 setup. Please let me know if there is any special route/setup I should test, thanks.
Kind regards
(CID:106206896)
Replies 8
1428
Hi Stefan,
Kind regards
(CID:106206896)
Off from the main question; how do we show the 7 racks connectivity on a report? as the network report or exported to excel only show start and end, not the 'hops' in between.
(CID:106207228)
Hi Chris, I think a possible option could be to export the route as image (File > Layout as image > Rack layout). I can capture a feature request if you/customer would need a more detailed/text based report? Kind regards
(CID:106207236)
Posted: ‎2020-07-03 03:38 AM . Last Modified: ‎2024-04-08 11:54 PM
Hi Jef, That methode works indeed in the selected room, but my routes spans over multiple rooms i think that's the problem. When i make in jour methode a route over multiple rooms i can't see the end point in my network management tab. Will you test that for us please? Many thanks!
(CID:106207300)
Hi Stefan, You are right, if the route spans over multiple rooms (2+), then I can see the issue. I have registered an enhancement case for this, so the codes could be reviewed,. Thank you. Kind regards
(CID:106207447)
Hi Jef, Many thanks for answering the questions. Hope for a quick result. Kind regards
(CID:106207450)
Posted: ‎2020-07-03 03:39 AM . Last Modified: ‎2024-04-08 11:54 PM
Hi Stefan, You are welcome, Kind regards
(CID:106207453)
Posted: ‎2020-07-03 03:39 AM . Last Modified: ‎2023-10-31 11:27 PM
