Network Summary Report issue with Tags
  • EcoStruxure IT forum
  • Network Summary Report issue with Tags
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 04:57 PM . Last Modified: ‎2024-04-05 12:04 AM
564
Dear all,
I am trying to generate network summary report using DCO 8.1, using Tags as filter. I have confirmed the tags has been assigned to both patch panel / network switches but when I choose the corresponding tag and generates Network Summary Report, it shows empty results.
However, if i didn't choose any tag and generates report, the report able to show all the result for the particular room.
I tested in DCO 8.2.2 and it shows the same result.
Sample tags assigned to patch panel
Empty result if tag choosen
Does anyone experienced this issue before? Did I missed out anything?
Thanks and regards,
TJ
(CID:130099662)
  • Data Center Operation
564
Hi TJ,
Can be reproduced, as you've described Network Summary reports based on tags doesn't seem to work and generating an empty page. I have logged an enhancement case for this, the case no. is DCO-10444 (for internal reference).
Kind regards
(CID:130682290)
Replies 4
565
Hi TJ,
Kind regards
(CID:130682290)
Thanks Jef!
(CID:130682357)
You are welcome, TJ
Kind regards
(CID:130682424)
Posted: ‎2020-07-04 04:57 PM . Last Modified: ‎2023-10-22 03:26 AM
This is a heading
