Posted: 2020-07-02 11:34 PM . Last Modified: 2024-04-09 01:10 AM
We're seeing gaps in our recorded sensor data for humidity over the last 24 hours. Is this normal, i.e does the Netbotz only record a new data point if the humidity value has changed?
(CID:105465257)
Posted: 2020-07-02 11:35 PM . Last Modified: 2024-04-09 01:10 AM
Hi all!
It seems to me, that it is more similar to the hardware failure. I confirm: on our NetBotz450 + AP9335TH + AP9520TH which is in operation since the beginning of 2010, also exists this problem. I.e., periodically for the unclear reasons on diagrams of temperature and humidity there are gaps.
About this problem I wrote for a long time, and since 2010 on our NetBotz450 the whole generation of firmware (actual version v4.5.1) was replaced, but the problem above specified sometimes appears.
From what I can draw a conclusion, that with a high probability the reason can be in noises and problems of communication with climatic sensors here (AP9335TH, AP9520TH, etc.), but not with NetBotz450 or its firmware.
Very thanks for the support.
(CID:105465274)
Thanks for the reply.
Can anyone confirm whether or not the Netbotz will record the same humidity value twice or more in a row?
Can anyone from APC confirm whether my guess is correct, and the Netbotz only records a value when it has changed from the previous value?
(CID:105465361)
Posted: 2020-07-02 11:35 PM . Last Modified: 2023-10-31 11:26 PM
