Posted: 2020-07-02 09:45 AM . Last Modified: 2024-04-10 01:07 AM
Is there a way to do an SNMP get command on a Netbotz 450/570?
DCE uses something else since you have to choose "Netbotz" when adding devices however I was hoping there would be a way to get information from the Netbotz via an SNMP Get command in another tool.
J
(CID:93194015)
Yes, you can get Netbotz data via SNMP. If you go to the below link and select "Firmware Upgrades - MIB" you can download the latest PowerNet MIB v4.1.2 which now includes Netbotz MIB data as well as all other APC products.
http://www.apc.com/tools/download/index.cfm
If you load that MIB into your NMS server or MIB browser tool, and you can walk the device and see what data points are available.
(CID:93194022)
Posted: 2020-07-02 09:45 AM . Last Modified: 2023-10-31 11:26 PM
