Posted: 2020-07-03 02:18 AM . Last Modified: 2024-04-09 12:20 AM
Hi Friends,
I have Netbotz Pod 150 and i want to discover that on Data Center Expert but it is not discovered. Netbotz has an IP and DCE can ping that. Credentials is correct, so i do not know what i am missing.. Can you help me ?
(CID:105472102)
Hi Kerem,
The NetBotz 200 is actually an SNMP device and is not quite the same as the 300, 400, and 500 series appliances. To add the NetBotz 200, you need to use the SNMP discovery option as noted in k-base FA225604. Additionally, the NetBotz 150 pod connects to the NetBotz appliance and is itself not network addressable. As such, you can not discover the pod itself rather the appliance that has the pod attached can be discovered along with any pods connected.
Steve
(CID:105472116)
Hi Kerem,
Steve
(CID:105472116)
Thank you Steven, it worked 🙂
(CID:105472122)
You're welcome.
(CID:105472127)
Posted: 2020-07-03 02:19 AM . Last Modified: 2023-10-31 11:26 PM
