APC AR3380G Genome
  • APC AR3380G Genome
128
Posted: ‎2020-07-03 02:18 AM . Last Modified: ‎2024-04-09 12:20 AM
729
APC AR3380G Genome
Hi, I need APC NetShelter AR3380G 42U Rack 800x1200 genomes. I cant find in Genomes Library.
(CID:105472069)
  • Data Center Operation
Hi Alper,
You are right, the NetShelter with the part number AR3380G is currently not included in the Genome Library. I will capture a request so it can be included in a feature version, but for the time being (as a work around) you might want to use a similar rack or customize a "Generic Rack".
Kind regards
(CID:105472153)
Hi Alper,
Kind regards
(CID:105472153)
Hello Alper,
I work for the genome team. I have raised the request for the APC NetShelter AR3380G on behalf of you. It will be processed soon. In the next DCO release you can see this genome in the list.
Thejaswi
(CID:105474271)
Posted: ‎2020-07-03 02:18 AM . Last Modified: ‎2023-10-31 10:16 PM
