Posted: β2020-07-02 05:28 PM . Last Modified: β2024-04-09 02:27 AM
Hi
can someone update me that Hydrogen sensor available in Netbotz APC solution? If yes what is the part number which is compatible with NBRK0570.
(CID:104174224)
Hi John,
There is not specific Hydrogen sensor in the Netbotz portfolie, but you can use a Netbotz 4-20mA sensor pod. A 3rd. party Hydrogen sensor which supports 4-20mA output can be connected to Netbotz 4-20mA sensor pod and give you the data in your Netbotz 570.
Jesper
(CID:104174231)
Posted: β2020-07-02 05:28 PM . Last Modified: β2023-10-31 11:26 PM
