Netbotz 570 Error "Communication error with device"
  • Netbotz 570 Error "Communication error with device"
129
72
Posted: ‎2020-07-04 04:31 AM . Last Modified: ‎2024-04-05 02:56 AM
870
Good day
Please assist
I'm loosing communication to our netbotz device 570.
I  receive email from DCE " The device is offline due to a timeout or connection error."
Then 2 to 5mins later i receive email from DCE "Device is online".
I am unable to identify what causes this issue as the error occurs is very random, however of late it has been occuring more frequently.
Any ideas?
(CID:128747490)
  • NetBotz
Replies 5
870
Dear juice,
This issue has already been discussed here on EcoStruxure IT. The simple search leads us to two possible solutions to your problem.
  1. Try to perform a simple diagnosis of your network between the NetBotz appliance and the DCE-server. For example, how did Steven Marchetti write about this in topic . Additionally, there, I told how to view the log files of your NetBotz appliance.
  2. A workaround solution to this problem may also be to change the mode of transfer of data from the NetBotz appliance to the DCE-server. I.e., use the so-called Post Only Mode. What is the difference and how to do it perfectly wrote VSales in the topic .
I hope this helps you solve the problem.
If there are more questions, please ask.
With respect.
(CID:128747667)
Posted: ‎2020-07-04 04:32 AM . Last Modified: ‎2024-04-05 02:56 AM
No the issue has yet to be resolved.
Viewing the logs - this is great however it doesn't really direct me to possible cause of the problem. The log files only says there was a communication issue and that's not enough for me to resolve the problem
Post mode - I am not comfortable yet with this feature, I need to understand what the pros and cons interms of my clients environment and measure the impact.
Thank you for the follow-up = much appreciated.
(CID:128755041)
In any case, thank you for the feedback 😀.
(CID:128755048)
Dear juice,
Have you been able to solve your problem or not?
With respect.
(CID:128755007)
Posted: ‎2020-07-04 04:32 AM . Last Modified: ‎2023-10-22 03:20 AM
