Posted: 2020-07-05 07:58 PM . Last Modified: 2024-04-03 01:23 AM
My Netbotz 550 is showing an Alert: Link Failed with Description: The link 'http://
How can I rectify this Alarm?
Thank you!
(CID:144869026)
Where do you see this alert? On DCE or on your monitoring software? Screen shot will be useful. Are you able to access the NBRK0550 Advance view or Web client through an IP address? Are you able to ping the device on your network? If you are not able to access the device on your network, then check the physical LAN cable connection to the ethernet port, try to access the device through direct local connection, check if you are able to access via HTTPS, check if HTTP is blocked etc.,
(CID:144869098)
Posted: 2020-07-05 07:58 PM . Last Modified: 2023-10-22 03:19 AM
