Netbotz 455 firmware update failure
  • EcoStruxure IT forum
  • Netbotz 455 firmware update failure
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 01:23 PM . Last Modified: ‎2024-04-04 12:33 AM
1030
Hi there,
I got a Netbotz 455 that can not login via the default user/password apc/apc (tried netbotz/netbotz and any combination posible) I can assign IP address via Serial Configuration utility but can not login via Advanced View. I connected via serial console and reset it to default values but still can not login. Try to do a firmware update, but no connection to the tftp server (tried 3 different tftp servers), eventhoug the netbotz and my laptop are in the same subnet (I ping from the serial console and the laptop IP adrees is alive). Any suggestions???
(CID:134688955)
  • NetBotz
Replies 8
1030
Hi Jose,
You mentioned not being able to log in using the default apc/apc user name and password. This at least would seem to indicate that the device is accessible. The first suggestion I would make is to reset the password to defaults using k-base FA158398.
If that fails, I suggest flashing the firmware using the tftp flash procedure outlined in k-base FA176133. This will both upgrade/reinstall the firmware as well as resetting the configuration should that be the issue (do not use the keep option to reset the device.
Steve
(CID:134688977)
Posted: ‎2020-07-05 01:24 PM . Last Modified: ‎2024-04-04 12:33 AM
Hi Steve
Thanks for the answer. I have done both procedures, but not sucess.
  • Restart the password, can not login with apc/apc.
  • Flashing the firmware, could no complete step 14, message in a) appears and eventhough I repeat it, not sucess.
(CID:134689027)
Hi Jose,
The only other suggestion I can make is to contact tech support directly. If you can do a remote session with them, perhaps they can see something that's not evident here. Also, if the device is faulty and under warranty, they can replace it if necessary.
Steve
(CID:134689460)
Hi there
Finally I could do the firmware upgrade, but when I try to access via Advanced View, an explorer window opens asking for an user and password. I have tried apc/apc but no success. Any ideas???
(CID:134692407)
Hi Jose,
If you're using Advanced View to try to automatically detect the firmware, perhaps there is a cponnection issue. What I would suggest is to manually download the firmware:
http://www.apc.com/us/en/tools/download/download.cfm?sw_sku=SFNBZ462&software_id=MFOI-ATYUGT&family=...
You can then use Advanced View and browse locally for the file.
Steve
(CID:134692636)
I already did the firware upgrade, I can access via Serial Utility, asign an IP address but when I try to access via Advanced View, it asked me about user and password, I use apc/apc, but no success. Try to reset to default but no able to access via Advanced View. I have tried procedure http://www.apc.com/us/en/faqs/FA158398/ but not able to access vía Advanced View. Any other way to configure the Netbotz 455???
(CID:134692754)
Jose,
Do you have any APC devices that are not NetBotz? The reason I ask is because the only way I can replicate your issue where launching advanced view, typing in an IP, then having a browser window open is when the device at that IP is not a NetBotz 3xx,4xx, or 5xx device. Perhaps there is another device that has the same IP and there's a conflict. If the web page login prompt looks like this, it's something with an NMC:
If the web page login prompt looks more like this, it's a 3xx, 4xx, 5xx NetBotz appliance.
Steve
(CID:134692792)
Posted: ‎2020-07-05 01:24 PM . Last Modified: ‎2023-10-22 03:19 AM
