Netbotz 355 - periodic report and other
  • Netbotz 355 - periodic report and other
129
72
Posted: ‎2020-07-05 01:28 PM . Last Modified: ‎2024-04-04 12:32 AM
693
Hi, can I configure the Netbotz 355 to send (via e-mail) a periodic report with only the temperature information  and graph.  Currently I received the report but it has information that is not required (is set up as OOT alarms).
Q2: I monitor for power failure use a ICM delayed restart relay and Botz dry contacts cable. Anyone have a simpler configuration / sensor ?
    The ICM is powered by direct connection to wall outlet.
     I use the ICM block because it will catch a under power or loss of power fast event
     and can be programmed to stay in failed state for 1 to 10 minutes (I use 2 minutes
     to ensure that Botz sees the event).
    The botz and network are power via UPS.
Q3: on my 320 and 400 Botz I can use the status command (e.g.
       address>/status. This does not seem to work on my 355. Any thoughts?
Thank you,
Nanoman
Graphic of power fault monitor.
(CID:134689675)
  • NetBotz
Posted: ‎2020-07-05 01:28 PM . Last Modified: ‎2023-10-22 03:18 AM
