Netbotz 250 Active Directory
  • EcoStruxure IT forum
  • Netbotz 250 Active Directory
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 04:44 PM . Last Modified: ‎2024-04-05 12:08 AM
809
I have a client with 9 x Netbotz 250's, all with rack access equipment installed.
He would like to know if the card ID's can be set up with Active Directory, or if they all need to be configured manually.
(CID:130097946)
  • NetBotz
Posted: ‎2020-07-04 04:45 PM . Last Modified: ‎2024-04-05 12:08 AM
808
HI Paul!
Netbotz 250 can not be directly intgrated with AD.
Using RADIUS server authentification can be an option in your case.
You need to switch on RADIUS autentification in Rack Access settings and configure dictionary and user files.
(CID:130097958)
809
HI Paul!
(CID:130097958)
Cool, thanks for the answer Valentin
(CID:130682401)
Posted: ‎2020-07-04 04:45 PM . Last Modified: ‎2023-10-22 03:16 AM
