DCO 3D temp. issue
  • DCO 3D temp. issue
129
72
Posted: ‎2020-07-04 04:45 PM . Last Modified: ‎2024-04-05 12:08 AM
1013
DCO 3D temp. issue
Hi Team ,
We config DCO and showed 2D was very well . When turn to 3D mode , it's showed cooling is not
enough ,the temp. may incorrect . I'm tring to add more cooling but the result was the same ,
can someone advice what's the problem'on it ? Many thanks.
Best Regards
(CID:130098033)
  • Data Center Operation
1013
Billy,
Your cold aisle containment need to cover the rack, not only till the front door of the rack
Look at the video example around 6 minute on how to model the containtment.
The video showed hot aisle containment, but the method is the same.
http://sxwhelpcenter.ecostruxureit.com/display/VIDEO/How+to+model+different+types+of+cooling
(CID:130098046)
Replies 4
1014
Billy,
(CID:130098046)
Hi Chris ,
Thank you ,I will check it later .
Best Regards
(CID:130098674)
Hi Chris ,
Best Regards
(CID:130098675)
Posted: ‎2020-07-04 04:46 PM . Last Modified: ‎2023-10-22 01:29 AM
