Posted: 2020-07-02 02:41 PM . Last Modified: 2024-04-09 04:08 AM
Hello All,
Has anyone seen any issues connecting the Netbotz 200 with a Cisco 2248tp?
We have several Netbotz 200 and are struggling to get a consistent connection to a variety of Cisco 2248TP Fabric Extenders.
Some will connect straight away, some will only sync up when we force 100 Full-duplex, some will become 100 Half-Duplex and various other combinations.
Symptom is that the link light on the 2248TP does not come on and the NB200 (via Serial console) says Link Down). Plugging in to a different device the link light on the FEX works, taking the NB200 to another FEX may or may not work. Taking a working NB200 and plugging a different NB200 (same FW) wont work.
Very confused.
The FW on the Nb200 are all the same at ...
NB200: v3.7.5
AOS: v3.7.5
Craig
(CID:99157968)
Posted: 2020-07-02 02:41 PM . Last Modified: 2024-04-09 04:07 AM
Yes - I have had issues with a NB 450 and Symmetra ups connecting to FEX modules. Checked/tried everything. Thinking nexus bug. Ended up connecting to a catalyst with no issues.
(CID:99158147)
I believe this is a known issue between NMC1 products and Nexus switches, where the NMC will continually fail to negotiate to 100/F no matter what switch port or NMC setting is used. We see this issue on literally hundreds of devices, and have had to resort to placing NMC1 devices on 48-port unmanaged switch/hubs that can deal with 10/H and 100/H just to get comms consistency.
(CID:99157995)
Dear Craig Oberg
(CID:101613711)
Posted: 2020-07-02 02:41 PM . Last Modified: 2023-10-31 11:23 PM
