Posted: 2020-07-03 03:26 PM . Last Modified: 2024-04-08 12:58 AM
I have a client that has the following issue:
NetBotz web client showing Fahrenheit but AV shows Celsius how can you change the web client to display in Celsius?
TIA
Mike
(CID:116924140)
Posted: 2020-07-03 03:27 PM . Last Modified: 2024-04-08 12:58 AM
Hi Mike,
k-base FA290460 addresses this question about temperature on the NetBotz web page. If you're using IE, changing the computer region changes the page between Celsius and Fahrenheit. On any other browser, if it has it's own regional setting as Chris mentioned, that would be the way to change it.
Steve
(CID:116924248)
Mike,
Change your browser's language setting to say English UK,and you should be seeing reading in Celcius
(CID:116924145)
Hi mike sutton,
There is already an answer to this question, for example, .
With best regards.
(CID:116926239)
I have already tried that, see settings already applied below:
Cheers,
Mike
(CID:116926222)
mike sutton, which browser do you use?
After changing the locale format, the browser was closed/opened?
With best regards.
(CID:116926237)
Chrome browser the settings were already applied
Cheers
(CID:116926235)
I.e., we can assume that the problem is solved thanks to the advice Christopherus Laurentius?
(CID:116926233)
The problem isn't solved the settings were already valid it is still displaying oF
(CID:116926231)
What OS on PC?
(CID:116926229)
win 10
Cheers,
Mike
(CID:116926227)
mike sutton, please show the screenshot of Region Configuration from APC Advanced View.
With best regards.
(CID:116926225)
Hi Mike,
Steve
(CID:116924248)
Posted: 2020-07-03 03:27 PM . Last Modified: 2024-04-08 12:57 AM
Hi mike sutton,
Tell me, please, you got to solve the problem or not?
(CID:116924648)
Hi All thanks for your responses I've been out of the country for a few days with no email so apologies for no reply.
I sorted it in the end running WIN10 and using google chrome, you have to change multiple settings not just your overall settings. all good now
(CID:117540520)
Posted: 2020-07-03 03:27 PM . Last Modified: 2023-10-22 03:15 AM
