Missing measured loads
  • Missing measured loads
127
65
Posted: ‎2020-07-03 03:27 PM . Last Modified: ‎2024-04-08 12:57 AM
813
We have found instances of missing measured loads in DCO (in web client and the desktop).  Sometimes both PDU's in a rack show no measured load in DCO and sometimes just one PDU shows measured load.  We have:
  • Checked the IP addresses
  • Checked the PDU's are still active
  • Checked the values (power and sensors) are still active in DCE (which they are) - eliminating connectivity concerns
  • We have unassociated and reassociated the devices
Any ideas would be appreciated.
(CID:116924205)
  • Data Center Operation
Replies 5
Hi Nigel,
I will contact you soon, thanks.
Kind regards
(CID:116926310)
Posted: ‎2020-07-03 03:28 PM . Last Modified: ‎2024-04-08 12:57 AM
Hi Nigel
Do the devices in DCO have any measurements when not associated yet? Also can you specify which types or devices it is that you see the issues on - and do you use Sensor Mapping?
Best,
Niels
(CID:116924795)
813
We are currently working on this (data provided offline).
(CID:118000620)
Hi Nigel & James,
Just a short note to share here, that according to the provided data, the device power bank information is not being reported correctly to DCO - and a request for a new ddf file have been posted/registered, thanks
Kind regards
(CID:118001062)
Posted: ‎2020-07-03 03:28 PM . Last Modified: ‎2023-10-22 03:03 AM
