NetBotz Rack Monitor 570
  • EcoStruxure IT forum
  • NetBotz Rack Monitor 570
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 08:11 AM . Last Modified: ‎2024-04-08 03:57 AM
695
Hi Team,
Could you please help to solve this issue
Error: The sensor pod of Dry Contact is closed
(CID:110005527)
  • NetBotz
695
As for the Dry contact these are just a two wire cable that you can able to configure as OPEN or CLOSE status. Please do ensure the dry contact cable use are the following:
There is a portion that you can tick or untick the status of the dry contact during "Normal Status" and "Alarm Status"
(CID:110005582)
696
(CID:110005582)
Hi Randy, Thank you for your comment
(CID:110006083)
Posted: ‎2020-07-03 08:11 AM . Last Modified: ‎2023-10-22 03:14 AM
