Share Your Feedback โ Help Us Improve Search on Community! Please take a few minutes to participate in our Search Feedback Survey. Your insights will help us deliver the results you need faster and more accurately. Click here to take the survey
Posted: โ2023-10-31 02:35 AM
We have installed the NetBotz rack Monitor 750 at one of our client site. The Rack monitor is not syncing with any wired sensor.
The Rack Monitor is running on the latest firmware (5.3.5). Only wireless sensor appears on overview page and alarm configuration page
I have connected the below sensor with Netbotz 750.
Temperature Humidity AP9335TH
Leak Rope sensor 0308
Posted: โ2023-11-01 05:36 AM
Did you try to reboot the Netbotz and see if the sensors detects? Or try disconnecting and reconnect the sensors one by one?
BR,
TJ
Posted: โ2023-11-01 06:19 AM
Dear Tjlw,
I have restarted the device 5 to 6 times and connected/disconnected the sensors, but the issue has not been fixed. Then I changed these sensors with a new box pack, but the issue remains the same.
Posted: โ2023-11-01 09:59 AM
I guess temp sensors are connected to universal ports and leak rope to the dedicated port
the last step should be to reset to factory default if you connect sensors after firmware update
Or is just a DOA and only replacement can fix that ๐
Posted: โ2023-11-01 10:10 AM
later edit
from your print screen, widget named appliance is missing
even without sensors you should see by default widget with switched outlet, output x2 and input contacts
Posted: โ2023-11-01 09:52 PM
Have you contacted support regarding this issue?
Another method you may try is to reset to factory default
https://www.apc.com/us/en/faqs/FA370681/
After reset is completed, try to connect the sensor 1 by 1 again.
If it is not working, please log a case to support.
BR
TJ
Posted: โ2023-11-01 10:52 PM
Hi Tjlaw,
I have already done that. However, the outcome has stayed the same.
Youโve reached the end of your document
