84589members
353856posts
NetBotz 420 Firmware
jkhuon
2862
I'm attempting to resurrect a NetBotz 420 that's boot-looping in U-boot with a "Bad Data CRC".
U-Boot 1.1.4 (Jun 13 2006 - 19:04:01)
CPU:   MPC885ZPnn at 120 MHz: 8 kB I-Cache 8 kB D-Cache FEC present
Board: NetBotz Cobra, Rev 0000 10MHz XTAL
       Watchdog enabled
I2C:   ready
DRAM:  64 MB
FLASH:  2 MB
In:    serial
Out:   serial
Err:   serial
DOC:   DiskOnChip Millennium Plus @ 0x7F000000, 32 MB
RTC:   Philips PCF8563
Net:   FEC ETHERNET
PCMCIA:No Card Found
Hit any key to stop autoboot:  0
## Booting image at ffe00000 ...
   Image Name:
   Created:      2006-06-14   0:05:20 UTC
   Image Type:   PowerPC Linux Kernel Image (gzip compressed)
   Data Size:    922658 Bytes = 901 kB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... Bad Data CRC
NetBotz>
My first thought is to reflash the kernel image but I can't seem to find a copy of the firmware anywhere.  Can someone point me in the right direction?
APC_Steve
Commander Commander
2853
Re: NetBotz 420 Firmware
Hi @jkhuon ,
If this is indeed an issue with the firmware, a TFTP flash of the system should resolve it. Instructions for that procedure are here:
http://www.apc.com/us/en/faqs/FA176133
Please note this mentions the newer units but it should be the same for the older ones as well.
As for the firmware, I've found a copy and put it on box where hopefully you can download it. I was able to download myself using edge but Chrome blocked it due to tftp.exe and a false warning about it. This link should be good for 2 weeks:
https://schneider-electric.box.com/s/vcfuuhnvgavjl8khnxs65p9t6vwmjvqo
12 Replies 12
APC_Steve
Commander Commander
2854
Hi @jkhuon ,
jkhuon
2847
Thank you.  This worked perfectly.
APC_Steve
Commander Commander
Glad I could help!
kentwv
2775
Hi, i was wondering if you could provide a working firmware link again? I have the same issue with bad crc.
Image Name:
Created: 2007-10-31 23:17:43 UTC
Data Size: 922648 Bytes = 901 kB
Any help would be greatly appreciated.
APC_Steve
Commander Commander
2755
Hi @kentwv You also sent me a direct message (which I saw first) so I sent you a link through that option ...it should be valid for 2 weeks.
kentwv
2753
Thank you! That worked for me.
kentwv
2752
If anyone else runs into this, i tried the above linked instructions and the postupg worked, but the rootupg still failed with bad data crc..
After some more searching, i found some instructions that had a "kernupg' command in between thet postupg and rootupg..
I did that and it was successful and then the rootupg worked after as well.
Thanks again to Steve for the files and help.
APC_Steve
Commander Commander
2749
Thanks...I forgot all about that kernupg. Isn't that in the instructions contained in the firmware (as opposed to the FAQ)?
kentwv
The firmware zip didnt have any instructions, i was just going by the faq link above.
sesa369561_FSR
Schneider Alumni (Retired)
2417
Hello
Can you share the box link again to download the upgrade file for NetBotz 420? I have some issue with a Netbotz 420 and I want to recovery it using the firmware file 2.6. Regards
Luis Lopez / SE FSR / SESA369561
Field Service - ITD - SE Costa Rica
APC_Steve
Commander Commander
2410
Here's the link for the file @sesa369561_FSR :
https://schneider-electric.box.com/s/l5wm88tubucf2vlpk6n1fxl0jv3ppni0
To all those that need the file in the future, please contact your local support directly as I will no longer be updating this post,
callanc
I too am in need of the latest/last Netbotz 420 firmware, I attempted to follow your instructions to contact support but I was told the following:
"Our concerned team has informed us that post your message and download issue in the forum: https://community.exchange.se.com/t5/EcoStruxure-IT-forum/bd-p/ecostruxure-it-forum
Could you please check and let us know?
Kind Regards,
Schneider Electric Exchange Support"
I attempted twice more telling them that the forum told me to contact support, but each time they replied with that same message.
It would be great if you could post a download link to the old firmware but without the 2 week expiration so in the future people like me don't have to bug you.
Alternatively, it would also work if this link was restored: http://updates.netbotz.com/patches/bw/2.6.2/tftpCobra262.zip
Sorry for re-opening this topic once again, but I'd rather do this than start a new topic.
Thank you for your concern,
Callan
