Posted: 2020-07-03 02:47 AM . Last Modified: 2024-04-09 12:11 AM
A customer requires the MIBs for AFX and In-Row units so that monitoring can be configured on a software called Solarwinds. Where can we locate these?
(CID:106204057)
Posted: 2020-07-03 02:47 AM . Last Modified: 2024-04-09 12:10 AM
As far as I know, APC In-Row Units Built in Network Management Cards use Power Net MIB.
You can download it here.
Can I have the exact model number of the AFX?
I hope it helps.
Bala
(CID:106204180)
I hope it helps.
Bala
(CID:106204180)
Hi, Bala the AFX Unit is: AFX 275616. Thanks In advance.
(CID:106204566)
I am unable to locate another MIB for AFX unit. If possible, please check if Power Net MIB works for AFX unit.
(CID:106204590)
Will do.Thanks.
(CID:106204688)
Posted: 2020-07-03 02:47 AM . Last Modified: 2023-10-31 11:23 PM
