equipment naming
  • equipment naming
127
65
Posted: ‎2020-07-03 02:46 AM . Last Modified: ‎2024-04-09 12:11 AM
761
equipment naming
could you help me about naming of equipmenst?
all equipmests are seeing only ip adresses.How to adres with label name.?
(CID:106204042)
761
Hi Murat,
To change this, you need to right click inside the Map View and select Edit Map.
Then right click again and select Map Settings. From there you can select Label from the drop-down list next to Show Identifier.
Click Apply and OK. Right click inside the Map View and select Save Map.
Then right click one last time and select Exit Edit Map.
Hope this helps.
Regards
John T
(CID:106204045)
Just to add to John's answer, if you are seeing IP under the hostname field and need to add a hostname, your DNS server must have that IP associated with a hostname and you must be able to ping it from DCE by hostname. The name should then appear in the hostname field in DCE after some time. Steve
(CID:106204053)
Posted: ‎2020-07-03 02:46 AM . Last Modified: ‎2023-10-31 10:56 PM
