Need DDF file for Akquinet Heat Exchanger
  • EcoStruxure IT forum
  • Need DDF file for Akquinet Heat Exchanger
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 03:17 PM . Last Modified: ‎2024-04-08 01:01 AM
1338
I need Cooling unit Akquinet Heat Exchange DDF file to be created with MIB file ( I have mib file ) and I don't have model no as it was customized unit for our  cooling requirement.
SaiaMIB_Classic.mibTEST.MIB
(CID:116921397)
1339
Hi Shaik Mahboob Ali,
In your case, you still need to request DDF-file according to , even if the model is not known.
Did you probably attach the MIB-file to the post? Unfortunately, as seen below in my screenshot, attachment deducted:
With best regards.
(CID:116921414)
Replies 14
1340
With best regards.
(CID:116921414)
yes I have attach its MIB file if you give my your email I will send
(CID:116922455)
I will be interested to look at the MIB-file. Just archive it, for example, in a zip or 7z format and attach it here.
With best regards.
(CID:116922457)
TEST.rar FYI attach
(CID:116922450)
FYITEST.MIB.zip
(CID:116922444)
Thanks, I received a TEST.MIB.zip file.
(CID:116922442)
Posted: ‎2020-07-03 03:18 PM . Last Modified: ‎2024-04-08 01:01 AM
I looked at your MIB-file: unfortunately, having only this file, you can not help.
 It would be very nice, if you created a special SNMP walk file for Akquinet Heat Exchanger. How this can be done simply by link How to create a SNMP walk file for Struxureware Expert/InfraStruXure Central.
With best regards.
(CID:116922440)
10.93.132.19.walk
 find the attach walk file plz
(CID:116922541)
Ok, that's what I need, I'll try to help.
(CID:116922549)
Really appreciate your support
(CID:116922559)
Shaik Mahboob Ali, I assume you have already successfully created a Device Request for Akquinet based on Saia PCD3.M controller?
Here is a screenshot of this request from April 17 this year:
I understood you correctly?
With best regards.
(CID:116922579)
Yes but the information i provided was incorrect and now i am trying to create a new request but i cannot , can you please advise
(CID:116922920)
Posted: ‎2020-07-03 03:18 PM . Last Modified: ‎2024-04-08 01:00 AM
You do not need to create a new request. Just need to additionally write a message on your akquinet request on the personal page YOUR DEVICE REQUESTS.
A couple more tips about your request.
Try to give developers maximum information about your device. After all, your device is based on the universal multi-function and expandable controller Saia PCD3.M5340. Therefore, for developers MIB-file is not needed, but you need snmpwalk-file. But in order to minimize the development time of the DDF-file, you need:
  • Exactly how many and what I/O modules are installed in the controller. As far as I was able to figure out, you only have connected one PCD3.W525 an analogue multipurpose module with four inputs and two outputs. Correctly?
  • Accurately report the assignment (e.g. water temperature, fan speed, fan on/off etc.) of each analog I/O line above the specified I/O module.
  • It is very desirable to tell, what information/data you plan to receive via the SNMP protocol in the DCE-server, for example, water temperature, fan speed, fan on/off etc. I.e., that the developers know exactly what, for example, the value of this SNMP OID from the snmpwalk-file is the water temperature, and the value of the other SNMP OID from the snmpwalk-file is the fan speed, etc.
  • In addition, it is necessary to understand that, if the controller of your device can generate SNMP traps (which can be described in your MIB-file, for example), the DCE-server will not be able to process them in the standard way. Because the DCE-server by its functionality can only accept the SNMP trap and then get the true information from the device only by running snmpwalk and by reading the information/data of the corresponding SNMP OID.
Always glad to help and answer questions.
(CID:116923740)
Posted: ‎2020-07-03 03:18 PM . Last Modified: ‎2023-10-22 03:09 AM
