Posted: 2020-07-03 03:16 PM . Last Modified: 2024-04-08 01:01 AM
Hi all!
Many people and I, in particular, are interested in the above question: are the command line parameters applicable for StruxureOn GW installer or not? And if so, what are the parameters?
Very thanks for the support.
(CID:116921371)
At this time, silent install is currently unsupported as it has some side effects which you noted. We have no firms plans to address this at this time. If you could share some additional background on your use case, that could help influence the priority. Thanks!
(CID:116922662)
I'm also interested in this. I've tried running the installer through silent mode via cli and it's adding a version directory which is then breaking the restore function and java relationship.
If I run 'C:\StruxutreOnGateway.exe \S" it'll do a silent install and the directory structure will look like this C:\Program FIles\StruxureOn Gateway\1.0.3
vs
If I run 'C:\StruxutreOnGateway.exe' and it'll be a interactive install with the directory structure like this C:\Program FIles\StruxureOn Gateway
(CID:116922461)
(CID:116922662)
Posted: 2020-07-03 03:17 PM . Last Modified: 2024-04-08 01:01 AM
Thank you for your reply, we will be happy to help the community 😀.
(CID:116922696)
Posted: 2020-07-03 03:17 PM . Last Modified: 2023-10-22 03:59 AM
