Posted: 2020-07-02 09:19 AM . Last Modified: 2024-04-10 01:15 AM
I have enabled my dce server as an NTP server and all the devices on this server needs to be changed to synchronize with the NTP server to rectify the date as per the example attached how do I do a mass config please explain.
(CID:93192809)
Hi Craig,
The steps are below:
F.Y.I If you choose multiple devices with different firmware revisions (3.x.x/5.x.x/6.x.x), you may not get all the fields listed above.
There is more information on this on the manual. The manual is below for your convenience:
http://www.apcmedia.com/salestools/JLER-7YYLX3/JLER-7YYLX3_R8_EN.pdf
I hope this answers your question.
Breda
(CID:93192818)
(CID:93192886)
Posted: 2020-07-02 09:20 AM . Last Modified: 2023-10-31 11:27 PM
