NBES0308 Leak Detection Rope (NetBotz 570)
  • NBES0308 Leak Detection Rope (NetBotz 570)
126
65
Posted: ‎2020-07-05 05:02 PM . Last Modified: ‎2024-04-03 04:17 AM
1949
Question regarding leak detection rope NBES0308 on NetBotz 570. Will alerts generated by NetBotz appliance provide the location on the rope where a leak was detected.
(CID:139694442)
  • NetBotz
1947
Hi Barry,
So, sadly that ability is not coded into the NetBotz appliance. You will only know that the sensor detects a leak or not. You can't see where. The only way to be more specifc in where the leak is would be to use multiple spot leaks instead of a single rope.
Steve
(CID:139694450)
Replies 6
1948
Hi Barry,
Steve
(CID:139694450)
Thanks Steve, good to know.  I appreciate your quick response to my question.  Thanks again.
(CID:140216852)
Put a grid of ropes on the floor ) Name the lines ABCDE and 12345. You will be able to detect the coordinate as precise as many ropes you used. i.e. A1, B2..  Battleship.
(CID:140217075)
Hi Andrey,
That will only work if he has multiple NetBotz appliances. Each appliance only supports a single rope leak connection. You can have extensions but again, the appliance can not isolate where on the leak sensor or any extension that the leak occurred. The only way to isolate the specific location when using a single netbotz appliance is to use the spot leak.
Steve
(CID:140217084)
Hi Steve, I'm sorry for the confusing comment. I'll try to figure out how to do a workaround.
(CID:140217163)
Posted: ‎2020-07-05 05:02 PM . Last Modified: ‎2023-10-22 03:07 AM
