NBES0308 Leak Detection Rope (NetBotz 570)
EcoStruxure IT Forum
  • Re: NBES0308 Leak Detection Rope (NetBotz 570)
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 05:02 PM . Last Modified: ‎2024-04-03 04:17 AM
2540
Question regarding leak detection rope NBES0308 on NetBotz 570. Will alerts generated by NetBotz appliance provide the location on the rope where a leak was detected.
(CID:139694442)
  • Data Center Expert
  • NetBotz
DCIM_Support
DCIM_Support Mentor
Mentor
2538
Hi Barry,
So, sadly that ability is not coded into the NetBotz appliance. You will only know that the sensor detects a leak or not. You can't see where. The only way to be more specifc in where the leak is would be to use multiple spot leaks instead of a single rope.
(CID:139694450)
Replies 6
DCIM_Support
DCIM_Support Mentor
Mentor
2539
Hi Barry,
(CID:139694450)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
Thanks Steve, good to know.  I appreciate your quick response to my question.  Thanks again.
(CID:140216852)
DCIM_Support
DCIM_Support Mentor
Mentor
Put a grid of ropes on the floor ) Name the lines ABCDE and 12345. You will be able to detect the coordinate as precise as many ropes you used. i.e. A1, B2..  Battleship.
(CID:140217075)
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Andrey,
That will only work if he has multiple NetBotz appliances. Each appliance only supports a single rope leak connection. You can have extensions but again, the appliance can not isolate where on the leak sensor or any extension that the leak occurred. The only way to isolate the specific location when using a single netbotz appliance is to use the spot leak.
(CID:140217084)
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Steve, I'm sorry for the confusing comment. I'll try to figure out how to do a workaround.
(CID:140217163)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 05:02 PM . Last Modified: ‎2023-10-22 03:07 AM
