Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
Motivair Chilled Door not recognized - DDF -
Showing results forΒ
Did you mean:Β
  • EcoStruxure IT forum
  • Motivair Chilled Door not recognized - DDF -
126
65
Back to EcoStruxure IT forum
Posted: β€Ž2020-07-05 06:10 PM . Last Modified: β€Ž2024-04-03 03:06 AM
950
I imported "Motivair Chilled Door"DDF for my DCE.
However, my ChilledDoor M12 Model is not recognized.
What should I check?
https://ddf.ecostruxureit.com/view/Chilled%20Door/Motivair
I attached the SNMP walk data for reference.
M12_SNMP walk data.xml
(CID:141264840)
  • DDF
Posted: β€Ž2020-07-05 06:10 PM . Last Modified: β€Ž2024-04-03 03:05 AM
951
Dear Shinya Matsuda,
In this case, it would be very correct to make Request modification on the DDF resource:
With respect.
(CID:141264907)
Replies 4
952
With respect.
(CID:141264907)
Okay! Thank you for your prompt support.
(CID:141264919)
Ok, very thanks for the good feedback πŸ˜€.
(CID:141264924)
Posted: β€Ž2020-07-05 06:10 PM . Last Modified: β€Ž2023-10-22 03:05 AM
