Posted: 2020-07-05 06:10 PM . Last Modified: 2024-04-03 03:06 AM
I imported "Motivair Chilled Door"DDF for my DCE.
However, my ChilledDoor M12 Model is not recognized.
What should I check?
https://ddf.ecostruxureit.com/view/Chilled%20Door/Motivair
I attached the SNMP walk data for reference.
(CID:141264840)
Posted: 2020-07-05 06:10 PM . Last Modified: 2024-04-03 03:05 AM
Dear Shinya Matsuda,
In this case, it would be very correct to make Request modification on the DDF resource:
With respect.
(CID:141264907)
With respect.
(CID:141264907)
Okay! Thank you for your prompt support.
(CID:141264919)
Ok, very thanks for the good feedback 😀.
(CID:141264924)
Posted: 2020-07-05 06:10 PM . Last Modified: 2023-10-22 03:05 AM
