Modbus RS485 to MODBUS/IP Converter
  • EcoStruxure IT forum
  • Modbus RS485 to MODBUS/IP Converter
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 11:38 AM . Last Modified: ‎2024-04-10 12:11 AM
2017
Hello All,
I have a number of MODBUS RS485 devices that I would ultimately like to be able to monitor in DCE.  While I know I will eventually need a DDF the first challenge is to get the RS485 (Serial) MODBUS converted to MODBUS/IP.  I am thinking about using the Schneider 174CEV30010 Modbus to Ethernet Bridge and wanted to know 1) will that work?  and 2) what are others already using out there, ie is there a better way?
Craig
(CID:95355662)
2017
Hi  Craig,
We are using the Schneider TSXETG100 Modbus Ethernet Gateway in multiple sites to connect to our power meters and NSX Circuit Breakers via the TVR00210 Modbus interface module to DCE
http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=TSXETG100
Richard
(CID:95355664)
Replies 6
2018
Hi  Craig,
Richard
(CID:95355664)
Is Schneider EGX300 compatible with DCE7.24 and higher? Since version DCE 7.24 I have problem with timeouts on ethernet side.
(CID:95355667)
Posted: ‎2020-07-02 11:39 AM . Last Modified: ‎2024-04-10 12:11 AM
2017
DCE is not suitable software for MODBUS devices. Since version 7.24 is not compatible with Modbus devices. See:  Problem with MODBUS devices timeouts on DCE 7.2.4-7.2.6.
Almost two months I have no solution from the  Schneider.
Better tools for MODBUS devices is Shneider Electric Power Monitoring Expert.
(CID:95355666)
So what is the resolution for Modbus discoveries? So we put two solutions at client side: PME for Modbus devices and DCE for SNMP?
(CID:96043192)
Dear Tomastsk, Has the issue been solved now? Because I meet a same situation now and expect some suggestion from you. Thank you.
(CID:103585162)
Posted: ‎2020-07-02 11:39 AM . Last Modified: ‎2023-10-31 11:22 PM
