Minimum wireless sensor battery
  • EcoStruxure IT forum
  • Minimum wireless sensor battery
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 08:46 PM . Last Modified: ‎2024-04-03 01:06 AM
843
I would like to know when a wireless sensor (NBWS100H or NBWS100T) will stop working because of low battery.
I have seen in the preconfigured treshold that the minimun is 2.2 V. Below 2.2V, would the sensor stop working?
Regards
(CID:147196123)
  • NetBotz
We replace our batteries at 2.5V. If the pre-configured threshold is 2.2V then presumably you'll start losing reliability at or below that value depending on environmental factors that impede with the devices ability to communicate. You may also see sensors go into battery saving mode.
Given how cheap the cells are, you should plan to replace cells before the minimum voltage threshold to ensure reliability.
(CID:147198011)
(CID:147198011)
Posted: ‎2020-07-05 08:46 PM . Last Modified: ‎2023-10-22 03:02 AM
