ACRC301S Chilled Water Flow 0.0GPM
  • ACRC301S Chilled Water Flow 0.0GPM
127
65
Posted: ‎2020-07-05 08:46 PM . Last Modified: ‎2024-04-03 01:06 AM
967
InRow ACRC301S Chilled Water Flow has value of 0.0GPM as displayed from GUI. Verified by running SNMP MIB walk which has OID .1.3.6.1.4.1.318.1.1.27.1.6.1.2.1.3.1.2 = INTEGER: 0.  Possible bug with Chilled Water Flow sensor?
(CID:147196198)
  • DDF
Dear Barry,
Can you navigate to the below menu options on the unit display and confirm if you are read the Chilled Water Flow?
Main > Status > Detailed Status > Chilled Water Flow
If you see abnormal value over on the unit's display also, then I suggest you to contact your regional Schneider Electric's technical support as this may require certified cooling FSR to inspect this sensor in my opinion.
Bala
(CID:147196343)
Posted: ‎2020-07-05 08:46 PM . Last Modified: ‎2023-10-20 04:54 AM
