Posted: 2020-07-03 09:18 AM . Last Modified: 2024-04-08 03:35 AM
Hi all,
Since we running with almost the newest version of DCO 8 in particular 8.01 and switched from Debian 6 to CentOS 7 we have noticed that the memory usage is nearly 100% stable. Java is the process that consumed this much memory and im asking if there is anything we can do to reduce this usage?
Im thingking of a memory restriction , that java only could use 60% of the total memory, if this will solve the problem is a second question.
Yours faithfully,
Joe
(CID:110008801)
Hi Joey (Joey vd Mark),
DCO 8.0.4 is released.
This release contains several minor fixes, and a fix for a memory leak that exists in all previous DCO 8.x.x releases.
It is highly recommended to upgrade any previous versions of DCO 8.x.x to 8.0.4.
The download link can be obtained via customer care center and/or local tech support,
Kind regards
(CID:111414385)
Hi Joey, Would you mind to share a screen capture showing what you are seeing, thanks. It would also be great if I could see a capture from server webmin > "System Information" page. Kind regards
(CID:110008806)
Hi Joey,
It might be a memory leak issue, so I was wondering if it is possible to ask for your server logs?
server logs can be collected from server Webmin interface (https://
I will send you an invite to my =S= box shortly, just in case if you would kindly share your logs with me, thanks.
Kind regards
(CID:110012863)
Will do.
(CID:110013776)
Kind regards
(CID:111414385)
Hi Jef,
Thanks for the headsup, I will look in to it and plan this upgrade.
Kind regards
(CID:111414394)
Ladies and gentlemen,
we got it him:
Thanks for the support!
(CID:126159110)
Posted: 2020-07-03 09:18 AM . Last Modified: 2023-10-22 03:02 AM
