Posted: 2020-07-03 09:19 AM . Last Modified: 2024-04-08 03:35 AM
In the web client I see the measured power from a rack PDU even though there is no up stream connection from that PDU. However in the desktop client there is no measured information.
Is this meant to be the case?
(I like the fact I can see it in the web client)
(CID:110008839)
Hi James,
Many thanks for clarification (provided off-line), The web client was basically designed for Co-lo customers, who do not need to know about the possible configured power path. And therefore, I believe, the web client (per design) would be able to show the measurements for the associated rpdu’s (even though they have no configured power path at all). But in the desktop client, the Capacity information in “tool tip” (including the measured loads) would require a valid power setup in order to do the capacity/power calculations.
Kind regards
(CID:110009351)
Hi James,
Kind regards
(CID:110009351)
Thanks for the reply Jef
(CID:110009726)
Posted: 2020-07-03 09:19 AM . Last Modified: 2023-10-22 03:01 AM
