Maximum capacity of Racks
  • Maximum capacity of Racks
127
65
Posted: ‎2020-07-04 04:18 PM . Last Modified: ‎2024-04-05 12:16 AM
1065
Jef Faridi As you can see attached is the capacity and change license of our customer which is almost about to finish
I wanted to confirm what is the maximum capacity for the number of racks license i have to update it to the customer and also what about change is it the same ?
Pls suggest ?
(CID:130093023)
  • Data Center Operation
1065
Hi Wassem,
This setup is limited to 8000 racks, so if you/customer should need to add more license keys, then please make sure that you have the same amount for each module.
For example if you need additional 1000 rack license, then you would need:
1000 rack license for DCO Colo
1000 rack license for Capacity
1000 rack license for Change
Kind regards
(CID:130093051)
Replies 4
1066
Hi Wassem,
Kind regards
(CID:130093051)
Jef Faridi
thanks for the reply and info jef
and could you please tell me what is the maximum capacity racks license that is currently available ?
up to how many racks we can add to the solution ?
(CID:130093083)
Posted: ‎2020-07-04 04:19 PM . Last Modified: ‎2024-04-05 12:16 AM
Hi Waseem,
We do not have limitation, you can add as much license keys as you wish.
However, depending on the size of the setup (and growth) you might want to cross check the recommendations:System requirements
Kind regards
(CID:130093127)
Posted: ‎2020-07-04 04:19 PM . Last Modified: ‎2023-10-22 03:01 AM
